Hi
Versa version 2.84
iphone 7 version 12.1.2
Went to update Versa and got stuck with the message above
Now won’t sync at all and stuck in loop
I have tried all of the rebooting phones and Versa. Tried all the switching off Bluetooth tricks. Tried deleting the app.
Next suggestion please??
Frustrated!
Best AnswerThis sounds like a communication error but I'm unsure as to what might be causing it. Have you checked that your phone has a data connection, or the fitbit app hasn't had data restrictions turned on in your phones settings.
Seeing as you have listed everything you have already tried, the only other thing I can think of is a factory reset. As you haven't got access to your devices menu, you would need to initiate the reset by using a button combination.
On the watch, hold all three buttons for about twelve seconds. This will trigger the 2-button hardware restart after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, whilst continuing to hold the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
