11-07-2019 08:53
11-07-2019 08:53
I have been using "versa dashboard" as my watchface for a while and it has both a bluetooth connection icon and the optional feature to vibrate when disconnected.
I'm not receiving most notifications and I'm seeing the watch disconnected constantly. This is a relatively recent development, maybe the last app update?
Pixel 3 XL + Versa 1
I can get it to sync manually after some tries usually.
It seems like there are software releases that work well for weeks at a time and then these really rough patches.
I'm tired of the resetting/reconfiguring stuff -- is there any known issue being tracked and fixed? It seems like others are experiencing variations on this theme.
11-09-2019 08:50
11-09-2019 08:50
Hi @lance.lascari , in order to help you the best way possible, would you be so kind as to post the exact name of the watch face you're using: in the dashboaod of your Fitbit app, press the watch icon - press clocks - on top on the left side you see "My Versa 2" - press the Watch icon in the middle and you will see the name of the watch face, thanks in advance and regards, kuzibri
Best Answer11-09-2019 14:31
11-09-2019 14:31
I have a Versa (1) and it is "Dashboard" by BV designs".
I don't think the problems have anything to do with the watch face, the problems are the bluetooth connectivity and notifications/syncing being completely unreliable again.
The watchface option to vibrate when disconnected let me know how bad this problem had become. In the past it would disconnect and I would get a vibration and either it would connect by itself or I could force the issue. It was regularly disconnecting and reconnecting over the span of minutes or tens of minutes and I turned that option off because it was going to keep me up while trying to sleep.
I'm not getting notifications reliably... not good.
Best Answer11-09-2019 15:26
11-09-2019 15:26
Hi @lance.lascari , which phone are you using? Found the CFand only can help when I know which phone you're using. regards kuzibri
Best Answer11-09-2019 15:27
11-09-2019 15:27
Pixel 3 XL
Best Answer11-09-2019 16:56
11-09-2019 16:56
Hi @lance.lascari , although you think that your CF is not the problem (Third Party One), I would suggest to change your CF to one developed by Fitbit and after that restart your Versa and see if your problems are solved. Regards kuzibri
Best Answer12-08-2019 12:36
12-08-2019 12:36
How in the world are you getting a vibration notification when your Versa disconnects from your phone? I've had my Versa a few months and to the best of my knowledge there was no way to get the Versa to notify you of a Bluetooth disconnection e Therefore, you get no notification when you are leaving your phone behind, which is the biggest reason I started using smart watches.every watch I've had, even the cheapest had this feature.
Best Answer12-08-2019 14:19
12-08-2019 14:19
This was a feature of the watch face itself. If when selecting a watchface you search for "bluetooth" you can find some that will show a bluetooth icon on the face to show the connection and some have this vibrate feature. I think it should be a built-in thing, and I only use it because the connections are hideously unreliable (across multiple mainstream phone models, multiple Fitbit trackers) in my experience.
