05-20-2018 13:32 - edited 05-20-2018 13:43
I got my versa last week and all set up with my S8 phone. Since then I get a constant notification sound every 40-50 secs. There is no notifications that are coming in with this sound. If I shut my volume off then it will vibrate every 40-50 minutes. I get all my other texts, calls etc ok, no problem there. Its just this contant sound. If anyone has any input , I would greatly appreciate it!
Thank you.
05-22-2018 16:56
05-22-2018 16:56
The last couple days I was changing one thing at a time so I could go through the elimination process. Today I was just going through making many changes and it just stopped so I reallyhave no idea what really hsppened. Wish I did. Is it possible to delete this whole post since I got it fixed?
05-20-2018 14:32
05-20-2018 14:32
@lena2350 wrote:I got my versa last week and all set up with my S8 phone. Since then I get a constant notification sound every 40-50 secs. There is no notifications that are coming in with this sound. If I shut my volume off then it will vibrate every 40-50 minutes. I get all my other texts, calls etc ok, no problem there. Its just this contant sound. If anyone has any input , I would greatly appreciate it!
Thank you.
Try a RESTART and do it several times if necessary.
05-20-2018 18:15 - edited 05-20-2018 18:17
Thank you so much for your reply
I just tried a reset and nothing changed. How
many times does one have to go through that?
05-20-2018 18:48
05-20-2018 18:48
You did a Restart, not a Reset. The only thing left to do is a Factory Reset which restores your tracker to the way it was when you got it and then you have to start all over again. Or you can contact Customer Service. They, however, will ask you to do the same. Swipe left to Settings. Touch and scroll down to About. Touch and scroll down to Factory Reset.
05-20-2018 20:01
05-20-2018 20:01
Actually , the first time I did do a reset where I erased everything and started new from factory settings. I thought that's what you were telling me to do. My mistake, and it did not work. The 2nd time I did a restart. So far so good!!! Keeping my fingers crossed! Thank you again for taking the time to reply and help me. I really appreciate it!
05-20-2018 21:05
05-20-2018 21:05
I spoke to soon, it's still doing it. Ugh. I guess I will have to contact customer setvice.
05-21-2018 07:26 - edited 05-21-2018 07:26
Very sorry to hear that Iena. Be sure and tell Support all that you did to try and fix.
05-21-2018 20:36
05-21-2018 20:36
05-22-2018 15:12
05-22-2018 15:12
The 40-50 minute vibration may be occurring because you have the reminder to move function on and you are not putting in the 250 steps every hour. If you have that function on, the device will vibrate at 10 of the hour to remind you to move.
05-22-2018 15:24
05-22-2018 15:24
Read the original post again. Her vibrations are at 40-50 SECONDS.
05-22-2018 16:09
05-22-2018 16:09
Thank you for your reply but I had that notification turned off. I could possible live with it if it was every 40-50 minutes but this was seconds lol I think I got it fixed today , I am hoping. Thank you again for your input.
05-22-2018 16:37 - edited 05-22-2018 16:37
What finally fixed it, Iena?
05-22-2018 16:40
05-22-2018 16:40
The above is a direct quote. She said minutes.
05-22-2018 16:47
05-22-2018 16:47
My mistake, thanks for pointing that out
05-22-2018 16:47
05-22-2018 16:47
You/ are absolutely correct. I should have read more carefully myself. In the first sentence, she says SECONDS and I stopped there.
05-22-2018 16:56
05-22-2018 16:56
05-22-2018 19:32
05-22-2018 19:32
No, we can't delete the thread.
