01-12-2019 08:20
01-12-2019 08:20
after a half hr drive to work fitbit logged me as 1350 steps and 10 flights of stairs...crazy looking for any suggestions to solve this
01-12-2019 10:03
01-12-2019 10:03
You can log a driving activity for that period, that should remove any steps and floors that were added during that time.
Alternatively you can use the Drivebit app on your phone. You press start when you start driving and stop when you finish, it will then automatically perform the steps posted above. Make sure to sync your Fitbit after so that the extra steps are removed from there as well as your account.
01-12-2019 10:03
01-12-2019 10:03
01-13-2019 08:56
01-13-2019 08:56
thank u for ur prompt response back yesterday...bit of a pain that the fitbit does this but this solution works like a charm👍🏻💜
01-30-2019 06:50
01-30-2019 06:50
i also just purchased a Versa, shocked to see ive done 10,500 steps after flying and then driving..... not what i expected.
why is the device so sensitive ? i don't like the idea of having to use a 3rd party piece of software to stop it from counting...…
Need to much better. never had problems with my original fit bit.
seem to gone back 5 years
@suzieqq wrote:after a half hr drive to work fitbit logged me as 1350 steps and 10 flights of stairs...crazy looking for any suggestions to solve this
