11-28-2018 18:19
11-28-2018 18:19
The accuweather app on my fitbit versa is not loading the correct weather it says a completely different temp than the actual temp, but it has the correct city? Then I check accuweather on my phone or computer and that will have the correct weather but its just the fitbit weather app that isn't correct I don't know how to fix this.
11-28-2018 19:56
11-28-2018 19:56
@2013161ps Is the app using Current Location setting or did you manually type the name of your city in the Settings of the Weather app?
11-28-2018 20:51
11-28-2018 20:51
Mine is in Celsius and I wanted Fahrenheit
11-29-2018 07:33
11-29-2018 07:33
How do you change the temperature on the weather app to farenheit? It defaults to Celsius.
11-29-2018 13:02
11-29-2018 13:02
@Minniebear @littlericky The app needs to be updated. Fitbit is working on it.
11-29-2018 13:11
11-29-2018 13:11
I have a versa as well, and have the same problem. When will I be notified of a solution?
11-29-2018 13:26
11-29-2018 13:26
@supercdub I am not aware of a specific date. I guess once it's rolled out we will see it in the Fitbit mobile app.
11-29-2018 17:52
11-29-2018 17:52
11-29-2018 18:32
11-29-2018 18:32
@littlericky Unfortunately, that does not hold true for all users. Not for Android and not even for everyone on iOS. The rest might need an update to the app.
11-30-2018 02:52
11-30-2018 02:52
This worked for me, thanks
12-25-2018 21:54
12-25-2018 21:54
I am having the same problem with Accuweather showering wrong city and showing temperature for the wrong city in Celsius. Everything was working until my Fitbit Versa updated to latest firmware.
@2013161ps wrote:The accuweather app on my fitbit versa is not loading the correct weather it says a completely different temp than the actual temp, but it has the correct city? Then I check accuweather on my phone or computer and that will have the correct weather but its just the fitbit weather app that isn't correct I don't know how to fix this.
12-26-2018 20:08
12-26-2018 20:08
Thanks worked perfectly on Galaxy S9
01-14-2019 07:03
01-14-2019 07:03
My "units" does not include anything for weather.
01-14-2019 12:01
01-14-2019 12:01
@Schrammy you need to go to Fitbit mobile app, tap Versa icon, tap on Apps, go to Weather, open settings for this app and there you will have units along with the locations.
