08-23-2018 14:48
08-23-2018 14:48
i've had my versa since april. a few days ago, the battery life lowered drastically. it is only lasting about one day. also, my heart rate is not being tracked & the sensor lights are not flashing on the underside of the watch. HELP!!
Best Answer08-23-2018 20:08
08-23-2018 20:08
@tam7983, I would contact customer support, if your led are not flashing there is something wrong. Even with heart rate monitor turned off you would see the green led flashing when you touch the sensor.
Best Answer08-23-2018 18:21
08-23-2018 18:21
Hello @tam7983
This sounds abnormal as the battery should last 5-6 days with auto sync turned off.
I would try 3 restarts in a row and see if that helps you.
If not, I'd try a factory reset and give it a few days before you call customer support.
See pg 68 below to walk you through the process.
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
08-23-2018 18:50
08-23-2018 18:50
I am having the same issue. My Fitbit was purchased in May.
Best Answer08-23-2018 18:53
08-23-2018 18:53
Hello @katinaerewa
Please try my suggestions I posted.
08-23-2018 20:08
08-23-2018 20:08
Best Answer08-24-2018 05:44
08-24-2018 05:44
I checked page 68 to restart my versa it says to hold the back button and the bottom button. What back button I don't have a back button on mine
Best Answer08-24-2018 05:48
08-24-2018 05:48
Back button is the button on the left side of your device. Bottom button is the bottom right button on the right of your device.
08-24-2018 06:05
08-24-2018 06:05
Thank you! My green LED light is still not on. I followed the previous instructions that were given in this thread to no avail.
Best Answer08-24-2018 12:50
08-24-2018 12:50
@katinaerewa, is everything else on your versa working. Just curious can you go to exercise mode from your versa and click on anyone of your shortcuts. Check to see if your heart rate is showing you anything. From your versa watch scroll to settings and see if your heart rate is on or off. There is no way to turn off the green LED it will always Continue to flash when it senses a pulse. If you tried everything suggested and still don’t see a green LED I would contact customer support.
