My iphone correctly displays the time as 12:14pm, but my fitbit versa says the time is 12:14am. I have tried toggling the timezone automatic setting but it does not fix it. Help! I want it to display the correct time!
On top of the home screen of this board, you'll see "Dashboard", press that and you will see the Dashboard. Press the settings on top of the screen on the right side, scroll down to "clock display time" and set it to 24 hours. Scroll further down to the bottom of the same page and press "Submit" and restart your Versa.
Best AnswerThanks for taking the time to respond. No, I don't want to change it to 24-hour format. I just want it to show AM/PM correctly. It is shown correctly on my iPhone. I synced my Versa multiple times, but it is still showing as AM when it should be PM
Tthat's of course up to you. Maybe this video can help you: https://www.youtube.com/watch?v=AtcUhScogGE.
Best AnswerSo there is no way to correct the AM/PM for the 12-hour format? The only way is to fix it is change it to 24-hour format?
Best AnswerHi, see my edited post just above yours. If that's not helpful, the only way is indeed to change it to the 24 hour format. Hope the video will be helpful!!
