12-22-2018 20:42
12-22-2018 20:42
I have noticed my Versa not picking up my heart rate after the update when I am working out or just sitting down. I have tried resetting it, moving it, checking settings, everything. I am getting very frustrated and am not sure what else to do.
12-22-2018 20:51
12-22-2018 20:51
@Abbi- Does Today app show the same "--" (swipe up on the main screen to open)? Have you tried toggling ON/OFF Heart Rate in Settings on your Versa with a reboot in-between? To reboot, press and hold the left and bottom right buttons until Fitbit logo flashes.
12-23-2018 09:16
12-23-2018 09:16
12-23-2018 21:12
12-23-2018 21:12
@Abbi- Well, you probably know what I am gonna recommend right now... I would try restoring your tracker to factory defaults. This will wipe your Versa, so please sync first. You will also need to delete your tracker from the Fitbit account (in the Fitbit mobile app) and your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a new device in the Fitbit mobile app. Good luck!
12-25-2018 16:30
12-25-2018 16:30
12-27-2018 16:31
12-27-2018 16:31
@Abbi- I agree, at this point I would reach out to Customer Support. Good luck.
01-02-2019 16:59 - edited 01-02-2019 17:00
@Abbi, I'm having the same issue. Was customer service able to help?
01-02-2019 17:27
01-02-2019 17:27
I am also having this issue. Turned it off and on. My fitbot also won't vibrate...
01-02-2019 19:01
01-02-2019 19:01
10-13-2019 22:31
10-13-2019 22:31
Versa not reading my heart rate as well after update.
