06-12-2018 13:43
06-12-2018 13:43
i m not able to pick.up and reject calls on versa i m using an android phone
06-12-2018 14:28
06-12-2018 14:28
There should be notification by the bottom right bitton, tapping should starry the call which must be done through the phone .
However this dendsson Android 7 or greater.
06-29-2018 17:10
06-29-2018 17:10
But how to reject calls? I tried to press the upper right red icon but it only stopped the watch, not the phone.
06-29-2018 22:06
06-29-2018 22:06
Pressing the reject, too right should do the same as the call reject on the phone, sending the call to your voicemail .
My i ask if your using the default contact and dialer apps?
06-29-2018 22:59
06-29-2018 22:59
I am using Galaxy S8+. No other caller or contact apps installed. Just a Caller Defender to filter spam.
06-30-2018 21:28
06-30-2018 21:28
I have an S8, running Nugget, with the default dialer and contact apps. When a phone call comes in, I'm able to accept/reject/text reply.
I'll assume you use the default calling app, if as you say you dont have any installed, your phone would not be able to receive or make calls.
Have you made sure your app and phone are up to date?
08-19-2018 14:30
08-19-2018 14:30
Galaxy S8+
Just got my Versa today! I can answer and decline calls. Am I also able to answer and speak to the caller?
08-19-2018 22:08
08-19-2018 22:08
Yes simply pick up the phone @dmariev your versa does not have a speaker or a microphone
I know what your going to answer with, but this was added in response to the users wanting this feature.
11-29-2018 13:16
11-29-2018 13:16
I just paired my new versa with my Samsung Note 8. I do not get the reject call option in the bottom right side of the watch screen. I really need this option if I am going to keep this watch. Any help would be greatly appreciated.
12-23-2018 09:05
12-23-2018 09:05
I have the exact same phone (Samsung Note 8 - Android 8.0.0 a.k.a Oreo) and I have the same problem. No reject call button on the bottom right. Just a 'hang up' icon on the top right. When I press that icon or the top right button, it dismisses the call on my watch, However,the phone continues to ring.
We need this fixed.
12-26-2018 19:06
12-26-2018 19:06
hi
I have s7 Samsung, not able to receive calls via versa?
12-26-2018 19:08
12-26-2018 19:08
I am not able to answer call from Samsung s7, pls help.
I have fitbit apps downloaded
09-02-2019 08:20
09-02-2019 08:20
I previously had an iPhone and received calls and messages but cannot get anything on my new Samsung A20. Not happy!!!😡😡😡
