08-05-2022
01:29
17:37
08-05-2022
01:29
17:37
Hi, do you know how to turn on notifications during exercises?
08-05-2022 03:42
08-05-2022 03:42
@beata. This might be the answer. Go to your Settings app on your Versa 3 > Quiet Modes > make sure Focus Mode is toggled to off. That is the only device setting that I'm aware of that will stop notifications during exercise.
Laurie | Maryland
08-05-2022 04:51
08-05-2022 04:51
I want to turn them on. Not off
08-05-2022
05:05
06:27
08-05-2022
05:05
06:27
Hi @beata. - there are a couple of other options that may help.
- Swipe the watch face to the right to get to Quick Settings and enable Do not disturb, don't forget to disable it
- Possibly schedule a do not disturb session on the phone may work and it will re-enable it after automatically.
- a sleep schedule on the watch may also work, but that would seem odd while exercising!
08-05-2022 05:14
08-05-2022 05:14
Hi, i want to turn ON notification when f.e. bike exercise it ON. I don’t want turn off the notification. I want them to be visible on watch when I ride on my bike.
08-05-2022 05:23
08-05-2022 08:33
08-06-2022 05:01
08-06-2022 05:01
Quiet mode is OFF. I can hear notification during exercise on my headphones but i don’t see them on watch’s display. My goal is to have them also visible on the display.
08-06-2022 05:15
08-06-2022 05:15
@beata. The Exercise app on the Versa 3 can only give vibration feedback. You wrote that you can "hear" notifications in your headphones. Are you starting your exercise on the Fitbit app by tapping on the "+" sign on the Exercise tile, then using the log option? This is a feature called MobileRun. This is the only feature that gives you voice cues. If so, that feedback can't appear on your Versa 3 screen. All of the data is being collected on your phone.
Laurie | Maryland
