04-15-2018
15:08
08:05
MarcoGFitbit
04-15-2018
15:08
08:05
MarcoGFitbit
Hi
Is the versa a upgrade on the charge 2 or does anyone know if they are bringing out a new charge 2.
Thank you.
Best Answer04-15-2018 15:26
04-15-2018 15:26
It's really a guessing game.
Some call the Ionic a Surge upgrade, because they both have GPS. Some call the Versa a Blaze upgrade, due to the lack of GPS. I consider both the Ionic and Versa to be a new category, smartwatch, but it all depends on the perspective.
You can google "charge 3" but..
It's a popular debate--do I get the new one, or hold onto the older one for a bit and see if they upgrade it?
04-15-2018 15:16 - edited 04-15-2018 17:32
I have a Charge 2 and plan on getting the Versa. Personally I think it's an upgrade. The Versa is considered a smartwatch. The Charge 2 is considered a fitness tracker. So I would think a Charge 3 would be considered a fitness tracker too. I don't know what they could do to improve on the Charge 2 to justify a new one, unless they make it waterproof, and add a built-in GPS. I like the thinness of the Versa and if they come out with a Charge 3 it probably won't be as thin.
Best Answer04-15-2018 15:19
04-15-2018 15:19
Hi Shelly
Thats what I was thinking I didn't want to go and buy the versa and then find out they are releasing a charge 3, I am thinking that the versa is the upgrade?
I agree Im not quite sure what they would do as the versa is water proof so I suppose you could shower/bath in it I would hope.
Mandy
04-15-2018 15:26
04-15-2018 15:39
04-15-2018 15:39
Hi
Thank you for the reply
This is the decision Should I shouldn't I :smiley frustrated:
Altho I'm not quite sure it would be much different to the versa even if they did pop out a 3.
