07-28-2023 13:23
07-28-2023 13:23
correct time on versa2 fitbit needs synced
07-28-2023 15:06
07-28-2023 15:06
Hi @MAPLEgrove142 the time comes from the device you use to sync, so try syncing a few times. Trouble syncing? click to read more.
07-28-2023 18:19
07-28-2023 18:19
If your tracker is syncing, through the fitbit app, check your app settings for timezone location. If it is set for auto, try manually setting the timezone. Then sync
