11-17-2018 05:00
11-17-2018 05:00
I have done a search and I don't find an answer so here goes. I am looking to purchase a fitbit versa so looking at all the capabilities it would have. I have nest cameras as my security and would like to know if I would get notifications if there are motion on those cameras and be able to see what the camera spotted. I currently have a motorola 360 and it does this and I really like this option. Any help appreciated.
Best Answer11-17-2018 09:14
11-17-2018 09:14
How do you receive notifications from Nest? Is it a push notification from the Nest app? If so you would be able to receive the notification on you Versa, however you wouldn't be able to view the video feed/image.
11-17-2018 09:14
11-17-2018 09:14
11-17-2018 09:24
11-17-2018 09:24
Ok. Thank you. On my motorola I cannot see any footage except for the little screenshot it gives so I am fine with that.
Best Answer11-17-2018 09:28
11-17-2018 09:28
Just to be clear, you will only receive the text portion of the notification. The image won't be part of what you see on the Versa.
11-17-2018 13:24
11-17-2018 13:24
I think your asking if you can have the notifications from the nest app sent to the Versa. The answer is yes and will be the same as what shoes in the notification center.
11-20-2018 03:58
11-20-2018 03:58
11-20-2018 03:58
Thank you. Rhat is what I wanted to know
Best Answer03-09-2019 13:37
03-09-2019 13:37
I am having difficulties with notifications showing on my Versa. I have downloaded the Nest app from Fitbit, but that seems to only work with the thermostat which I don’t have. I want the Nest cameras to send me a notification. How can I make this work? Thank you.
Best Answer03-10-2019 11:17
03-10-2019 11:17
Notifications don't go through the Nest app on your tracker @mrswilson83 .
As @N8teGee has asked, do you receive nest notifications on your phone?
In what way do you get them?
Through the notification settings, simple tell the P to send nest notifications the tracker .
