07-31-2018 08:54
07-31-2018 08:54
why is there no response to everyones issue of not receiving text messages on my android galaxy 8s+. I receive phone calls on my versa but no messages. I used to receive them but they recently stopped.
Best Answer07-31-2018 11:19 - edited 07-31-2018 11:21
I would check your settings in the app and permissions on the phone c
Not knowing what phone your having trouble with, I'm unable the help with this .
See my answer in this post. I would just be copy pasting.
07-31-2018 11:34
07-31-2018 11:34
I have a samsung galaxy s8+ and I have exhausted all troubleshooting suggestions on the help site and all my settings look correct.
Best Answer07-31-2018 11:43
07-31-2018 11:43
Then it would be time to contact.fitbit.com
08-01-2018 07:34
08-01-2018 07:34
Do this:
Go to bluetooth settings and Forget Versa
Reboot phone
Go to bluetooth settings add device
Add Versa
Go to Versa and turn off notifications (hold left button down 2 seconds) and then on again
Go to Fitbit app > text notifications, click on your messaging app
Then try it out.
Best Answer08-01-2018 08:46
08-01-2018 08:46
I agree with @Eriklb with the exception of going back to the phones Bluetooth to add the Versa.
This might work on iOS but will not work on Android and windows phones.
The Versa, like all other Fitbits can not be paired to the phone this way .you should get a rejected by Versa
If you remember you never paired your Versa this way when setting it up .
The app will do this when the Notifications are configured .
