10-21-2018
08:57
05:08
AlejandraFitbit
10-21-2018
08:57
05:08
AlejandraFitbit
Versa stuck at 'unlock with your phone', but I don't have sync setup any more. Instructions for device reset or factory reset on this forum don't work. Any ideas how to get this back to working?
10-22-2018
05:08
06:13
10-22-2018
05:08
06:13
It's great to welcome you @Bsom.
Thanks for troubleshooting this by yourself. To unlock your watch with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
Let me know how it goes. ![]()
04-19-2020 06:08
04-19-2020 06:08
I have same problem but i removed the versa from my profile in fitbit so now i can add it again
when i try A message appears "unlock with your phone "
05-23-2020 16:15
05-23-2020 16:15
I have the same problem.
the device ask me to unlock by cell phone, but I get a new cell phone. Totally boring!
06-17-2020 06:40
06-17-2020 06:40
I have also changed phone and trying to setup newly. Tried to reset but it comes back to screen with display. Fitbit app can detect it but watch can’t display pin instead asking to “unlock with phone”.. why can’t watch can work wirh the pin setup earlier ?
01-21-2021 03:50
01-21-2021 03:50
My device is not saved with the fitbit app and I'm unable to set it up with pin again. Tried to reset but it comes back to screen with display. Fitbit app can detect it but watch can’t display pin instead asking to “unlock with phone”....please suggest something to remove it or reset it .I can't unlock with the phone because the device does not exist on my phone.
kindly get back to
ananyaknagaraj@gmail.com
07-16-2021 16:19
07-16-2021 16:19
Did you get a reply to this? My fitbit is doing the same
09-07-2021 09:50
09-07-2021 09:50
Iam also facing same issue.. please someone can help to resolve this
Best Answer09-07-2021 14:41
09-07-2021 14:41
I was able to fix this after a 1hr call with customer support.. Your're not going to like the solution.
You have to factory reset your fitbit, which means you will loose everything.
Hold the button on the side until you see the fitbit logo. (Around 10seconds)
Keep holding, once the logo dissappears let go and then re-press and hold the button until you feel a vibration.
The logo should pop back up and white meaning you have successfully reset the device.
Goodluck!
10-05-2021 09:25
10-05-2021 09:25
Hi
I.have the same.problem with my Versa 3
Have a red notification
Unlock with your phone.....
I dont have the 4 digit password
How can you help
Please
11-25-2021 06:30
11-25-2021 06:30
I've got the same issue with my watch as I switched my phone. Suggest a way to reset it without my phone.
Best Answer12-27-2021 06:32
12-27-2021 06:32
I'm not seeing under my account screen an option for device lock
01-22-2022 10:57
01-22-2022 10:57
If this works thats great. But for me it didnt.
i was on the phone to customer service for ages and all i got was “wait for an email from warranty with instructions on what they can do”
so because my watch was locked, and they were unable to troubleshoot it or help at all, i have now been told that because my watch is out of warranty i have to buy a new one with a 35% discount offered.
i am outraged. So very disappointed with a company i have used for many years, to be told i now have to buy another watch because my perfectly fine one locked itself out and is unable to be resolved.
safe to say i will be taking it further. I am not happy with a discount for a new product when the watch i am using is perfectly fine and in great condition.
01-23-2022 23:12
01-23-2022 23:12
05-03-2022 20:39
05-03-2022 20:39
Hi did you ever get a resolution? I have the same exact problem and they offered me 35% for a new one as well. It’s ridiculous they can’t fix their own product. I’ve even tried emailing the ceo of the company which is google now. Any info would help.
05-04-2022 00:52
05-04-2022 00:52
06-24-2022 19:25
06-24-2022 19:25
Thanks! This does take MANY tries to time it right, but it worked to to a hard reset on my Versa 3! Now the "Unlock with Phone" message is gone, it does not ask for the 4 digit PIN, and the Versa 3 rebooted into the message "To start, download the Fitbit app".
To reiterate, I pressed and held the side button until the screen went black, the Fitbit logo popped up and then dissapeared. At that exact point, I let go of the button and quickly pressed&held before the Fitbit logo showed up again, and I kept holding until I heard a boot up jingle from the Versa 3! The release and re-press has to be done within one or two seconds at the correct time.
When it worked, after many tries, I heard the jingle and the Versa 3 booted into the initial, out-of-the-box screen.
06-28-2022 14:43
06-28-2022 14:43
This doesn't work...
Best Answer07-07-2022 10:39
07-07-2022 10:39
Me too!! Has this issue been resolved!!
Best Answer07-07-2022 10:42
07-07-2022 10:42
No link to be found via app, icon photo.Any new suggestions please Unable to pair or reset
