02-11-2019 23:06
02-11-2019 23:06
I tried restarting my phone as it keep saying "Notification service not running.A phone restart is requires to re enable notification on your tracker ". it is only working for test call, nothing apart from that. This is really disappointing i have purchased it yesterday and from day one i am facing such issue. i have enable notifications, i am a android user and my bluetooth and phone version both are compatible as per your compatible device chart. Please help to fix this.
02-11-2019 23:43
02-11-2019 23:43
@neh19 Phone model and OS? it seems like the Fitbit app (and Notification Service) is being killed. First, please restore Bluetooth connectivity:
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues.
If you have issues with the notifications, please do the following:
02-14-2019 01:55
02-14-2019 01:55
Thank you. Still facing intermittent call notification issue. However i am not getting any text message/whatsapp notification on my versa.
02-14-2019 12:49
02-14-2019 12:49
@neh19 what's your phone model and OS? Are you receiving notifications from other apps?
02-14-2019 13:06
02-14-2019 13:06
I have the same issues. Complete re-installs work for ant where between 1 hour and 1 day. The only solutions I can find suggest rebooting, cycling connections, etc. etc. Nothing helps and Fitbit has no direct customer service. Too many hours searching forums. To many attempts at poor solutions. Will Fitbit take a return of a three month old unit?
02-15-2019 04:01
02-15-2019 04:01
I am using Redmi note 5pro and OS is Android version 8.1.0. i am intermittently receiving call notification nothing apart from that.
02-15-2019 05:29
02-15-2019 05:29
Hi @ppickles. Good job of searching the Community forums. That’s always a good first step. Sorry it did not help in this instance. But you can find direct ways to contact support by scrolling to the bottom of almost any Fitbit page and tapping help. From there, you can scroll down to Get Support. They can answer your warranty question.
02-15-2019 10:55
02-15-2019 13:50
02-19-2019 23:46
02-19-2019 23:46
@Marrrmaduke i tried locking the application in background still no luck.
02-20-2019 00:46
02-20-2019 00:46
Have you found the option to fix the issue yet? I’m having the same issue:(
02-20-2019 11:02
02-20-2019 11:02
@neh19 alright, try downgrading fitbit mobile app to the version 2.74.2 (you will have to first uninstall the current build). You can find apk file on the internet. Then, turn off battery optimization as usual, enable all-day sync, always connected and keep alive widget. Lock in the background.
03-01-2019 10:22
03-01-2019 10:22
@neh19 Did you manage to resolve the issue? Did downgrading the app help?
