versa 2 wont sync with galaxy samsung
i have a versa2 which stops syncing the only way to get it to re sync is to do a factory reset any ideas or help greatly appreciated
3 REPLIES 3
Avoid factory reset it can kill the watch.
Once you have all setup and working try this
On the phone check battery optimizations [the options may be different in your version]
  • First go to Settings > Apps & Notification > Special app access
  • Click on Battery optimization
  • Now press the drop down menu [...] and select “All Apps
  • Click on Bluetooth and then select “Don’t optimize
  • Same with Fitbit
  • Next go to Settings > Apps  > Fitbit > Storage
  • Clear cache [not data]
  • Force stop the Fitbit App
my vera is rejecting the blue  tooth from my phone im trying to pair them again - this is a total pain
Try this sync tip, if things aren't too badly disorganised.
Logout then login in to the Fitbit App
On the main Today screen
Pull down to Refresh,
[a sync popup appears at the top,
- Note position of battery indicator, if its in the popup,
especially if on the left
and/or there is no green progress bar, if so]
Click on profile photo [top left]
Device photo [middle left]
Sync
Click on the circle,
[sometimes necessary to try a few times till
it reacts]
Once it reacts, after a some seconds [< 10]
A request to pair will appear.
If no pair prompt appears
Go back to the Today screen
Repeat the process
It may take several tries and a bit of patience to get sorted
