08-21-2023 20:33
08-21-2023 20:33
I do not use any apps and I usually only have to charge my versa 3 once a week sometimes more. Now it is having to be charged every day. It charges fine but drains rapidly. This just started last week.
08-22-2023 05:31
08-22-2023 05:31
Hi @tjmgray - unfortunately a sudden change of this nature can indicate a watch fault, or Fitbit App problem.
If water gets in then damage can occur which causes the watch to use more battery. If you have restarted it and that didn't help you can also try turning off the Phone's Bluetooth and in the watch Settings, turn off Status Indicators. That may help.
If it doesn't there remains a factory reset option but you may no longer be able to use the watch if there is a serious problem.
If it is still under warranty then it can be replaced, if need be.
08-26-2023 16:34
08-26-2023 16:34
Seems they are forcing a change to Google app, that fixed my issues
08-27-2023 08:16
08-27-2023 08:16
so do I need to change to a different app. I have the fitbit app and it is from goggle store.
08-27-2023 09:24
