02-16-2019 22:19
02-16-2019 22:19
I have tried the 'turning it off and on' routine with no luck.. it was working really well and then it suddenly stopped recording either... it doesn't record on the watch or sync to phone
02-17-2019 05:43
02-17-2019 05:43
Versa not tracking sleep records
02-17-2019 05:47
02-17-2019 05:47
My Versa has stopped tracking bmp and sleep too. Any advice appreciated.
02-17-2019 08:30
02-17-2019 08:30
@padtheway @SAH191 @Tammycat Welcome! Thanks for being part of our Community! Sorry to hear that your tracker isn't recording your sleep. Your device will start recording sleep after it detects an hour of inactivity. If you have a light sleep or move too much then this may difficult your sleep detection. Additionally you can try wearing your device on your non dominant hand to decrease the amount of movement it is subjected to. Finally you can restart your device. You can also manually log your sleep time. The restart should help with the heart rate reading too and I would add that clean the back of your device with cotton and rubbing alcohol. Also check these tips to improve the heart rate reading on your device.
Let me know how it goes!
02-17-2019 09:32
02-17-2019 09:32
Sleep tracking and HR stopped last Tuesday
02-17-2019 09:34
02-17-2019 09:34
Not helpful, have tried most things
Best Answer02-18-2019 01:11
02-18-2019 01:11
Have tried most things but will clean as you suggest and see what happens
Best Answer02-18-2019 04:41
02-18-2019 04:41
Best Answer02-18-2019 06:05
02-18-2019 06:05
I had a blaze and just upgraded to the versa. I never had a problem with sleep and hr from my blaze, so none of the suggested "solutions" are helpful. The only thing synching is stepcount.
My watch shows how much I slept, but it will not synch to my phone app.
