01-23-2019 12:12
01-23-2019 12:12
Today is the first time using the fitbit versa. The wallet icon shows on the device but not on the app. I cannot add a card. Is there anything i can do?
I am from malta, europe.
01-23-2019 20:54
01-23-2019 20:54
@Niecy17 @Antoinette94 I think at this point it might be indeed a good idea to reach out to Customer Support.
01-23-2019 12:29
01-23-2019 12:29
Me, too. Hopefully, a quick update will fit that. ![]()
Best Answer01-23-2019 12:29
01-23-2019 12:29
@Antoinette94 open Fitbit mobile app and tap on Versa icon. Can you see the Wallet there?
01-23-2019 12:39 - edited 01-23-2019 12:42
It's not there. I see clock faces, apps, media, How to use, and
accessories tiles, but no wallet. I have the Special Edition Lavender woven band rose gold version.
Best Answer01-23-2019 12:47
01-23-2019 12:47
@Niecy17 hmmm. Have you tried reinstalling the app?
01-23-2019 12:55
01-23-2019 12:55
Best Answer01-23-2019 13:02
01-23-2019 13:02
Yes I deleted the app and reinstalled .
01-23-2019 13:02
Best Answer01-23-2019 20:54
01-23-2019 20:54
03-07-2019 06:04
03-07-2019 06:04
I Too had the same issue. After trying below steps issue resolved.
1. Reset Factory setting in Fitbit (Go to Settings and perform Reset factory all data will be lost)
2. Unpair device from the mobile app (Delete option available on top)
3. Now Started the process from the beginning Signing up with New Email ID
4. FIrmware Downloaded and installed
5. After that, I am able to see Wallet Tile on Mobile App.
Best Answer03-07-2019 09:21
03-07-2019 09:21
It turned out not to be a real special edition according to support technician. It was returned to the vendor and replaced. Thanks.😉
