08-29-2022
08:00
17:17
08-29-2022
08:00
17:17
I changed phones and now the weather app won't change from C to F even when the units on the app has been changed. Have restarted both the phone and Fitbit several times and still no luck.
08-29-2022 09:06
08-29-2022 09:06
Mine was working. I had to do a factory reset because I could open exercises and now this weather widget won’t work properly.
Best Answer08-29-2022 09:33
08-29-2022 09:33
I fixed mine
To change the weather temperature unit, open the Fitbit app and tap your profile picture and the Versa 3 image then tap "Gallery" and "Weather". You might need to swipe up to find the app.
earlier I was in app settings and that was wrong place to be. Good luck.
Best Answer08-29-2022 10:34
08-29-2022 10:34
