Hi, I own three devices from fitbit, Blaze, Alta HR and flex2.
From the fitbit app, im not able to set a default device...i don't know exactly how the fitbit app handle 3 devices at the same time. Blaze is never the default, always the Alta HR the winner to be the default (right corner icon)... Also notifications, does not work very good when they are 3 devices paired
this is a no sense to not being able to set a default device and put others OFF ...
Answer from fitbit :
Hello Domenico,
Thank you for contacting us again about your multiple devices issue.
We inform you that you can do that but the device not used must be far away so it won't sync with your mobile or you have to turn your phone Bluetooth OFF.
Don't hesitate to contact us again if you have any further questions.
Sincerely,
Isa D et l'équipe Fitbit
My answer:
Hi,
Why we cannot choose the Device we want from the fitbit app?
Synchronizing 2 devices at the same time is a non sense if we cannot have more than one account.
Im sorry but i won't put my bluetooth off or i won't put my other device far from my phone just because you are not able to manage this issue...
Please update the fitbit app to be able to manage correctly 2 or more devices with the option to make a default device possible.
Thanks
Dominic
Moderator Edit: Clarified subject, updated label and formatting
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
