It's not at the notification settings. Go out from App. (tap on your picture) Where you see the option to select your account and underneath it you have the option to choose a device.
Choose your device. Than, underneath sync section, there is general section. There you need to choose 'notifications'.
There, under 'advance settings' you will find it.
If you haven't succeeded doing so, you can contact me at: 054-2929774.
I just contacted Fitbit and they added this for ionic and for versa but not for versa Light, which is what I have. Even though it is a newer device than ionic and versa. Seems ridiculous.
Can we get the feature added for Versa Light Fitbit?
You guys are lucky! Apparently they put the feature for Ionic and for Versa but not for Versa Lite (a device that they released just a few months ago). I would really like Fitbit to include this for the Versa Lite as well and the Versa 2, which is their latest Versa device.
Hi guys Frome some reason I cant update my Ionic to OS 3... its firmware is 27.33.1.30 Can some one help me with that? I don't have notification of an update available... David
I finally got the Firmware update for my Versa Lite and I now get Hebrew notifications. The only thing to fix is the direction of the text so it can be read from right to left. Is this something Fitbit is addressing?
Fitbit,I just got my new Versa 2 and would be loving it if it weren't for this annoying issue with the direction of hebrew text... Any plans to fix this?
Hi @Anaty! Great suggestion, thanks for sharing your feedback. I've moved it into a similarrequest. Post a comment or click on the thumbs-up to show your support.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
