Add Noom as a third party app to log food
Fitbit should really consider adding Noom as a 3rd party app.
50 Comments
Earwax
First Steps
Get Noom on here. It is a trending diet and health platform. I will have to switch to apple if we don’t get it added soon.
JRzMom
Recovery Runner
If everyone would fill out a survey naming Noom as a 3rd party app you
can't get enough info on, it may come to the attention of the right people.
Debbie Kearns
Klinger1951
First Steps
Please add Noom to Fitbit OR Fitbit to Noom as a 3rd party app. Noom is a great all-around program for health and weight loss. It is very frustrating that Noom does not correctly read the steps on my Fitbit. Please correct! Thanks.
Kathleen Linger
Tamari75
Jogger
Please get Noom compatible with Fitbit!!!  It’s a very popular app. Is there a survey I can fill out?
depoezenboot
First Steps
My Fitbit used to sync with Noom just fine. For the past several weeks it has not synced. I don't know what has changed, but if Noom is not an approved Fitbit 3rd party app, please add it!
Chelle21
First Steps
Add noon
phansford
Stepping Up
I think the app developers need to make Fitbit steps sync to Noom
App!  My blaze will not currently sync my steps over from the Fitbit App to Noom because the Fitbit App is not Compatible with the Noom App.
EdsonFitbit
Fitbit Moderator
Fitbit Moderator
Hi @phansford, thanks for taking the time to share your feedback about being able to integrate Noom app with Fitbit. This feature suggestion already exists so I’ve moved your post here as it is not currently planned.
macie1115
First Steps
Please add Noom as a third party app. I would love it if the food log would sync, especially!
AVAZ
First Steps
I've been able to sync steps since starting noom at the start of 2020, but food isn't updating across the apps.  Would love for that to happen as the viewpoint of nutrition is slightly different on the separate apps and I'd love to have both!
Spinach1978
Stepping Up
Using Noom has got my health back on track and I am considering buying a new Fitbit as I already use the Aria and would like the two apps to sync so I can log sleep, food, exercise etc once
Thecleaner
First Steps
Please add Noom as a third party app. I am enjoying Noom and if comes down to a choice I will forego the Fitbit.
Regards,
John_Hilo
First Steps
Noom is a highly popular and effective program and is certainly in harmony with Fitbit's purposes. Somehow, my Noom app gets my daily weight data from Fitbit which receives the data from WeightGurus.  That part works.  Noom does not, however, receive my Fitbit steps data.  Fitbit help sends me to Noom, who in turn send me to Fitbit.  No resolution yet.  Been working on it off and on since May 2020.  Maybe if Noom were in the Fitbit app gallery, things would work without all the huckeypuck?
John_Hilo
First Steps
Still a problem. Fitbit wont sync with my scale, either. I have a Versa. My wife has a Versa Lite. Everything works fine (syncing) on hers. Whats the dofference?
KMPitt
Recovery Runner
I would also like to be able to connect Noom to FitBit on the FitBit side.  I connected it from Noom but didn't give it all the correct permissions.  So then their help said to select Revoke Access in FitBit and try again.  Well now in Noom when I select FitBit it doesn't prompt me for any permissions.  When I check 3rd party apps in FitBit Noom is not listed.  Noom support has been unable to help me so they aren't connected at the moment and I have to manually enter my steps into Noom.
Jeanne23
First Steps
Please make Fitbit compatible with Noom.
John_Hilo
First Steps
I saw in my Noom settings that an organization named Validic is who requests read/write permissions regarding FitBit. Still doesn’t work.
LindaWU
Jogger
 I can see food logged in Lose it in my Fitbit app.  Can't see food logged in Noom in fitbit app. Please provide a similar interface from fitbit to Noom.  Noom does link to fitbit but only as a pedometer
KC1953
Jogger
Currently, get step counts from Fitbit for use in Noom app. Would like to see Fitbit use meal data from Noom in the Fitbit app so I don't have to enter meal data twice. Would be a nice added feature and make both apps better for it.
Gordon-C
Premium User
Fitbit Developer
Fitbit Developer
Hi @LindaWU
We make the Fitbit APIs available for 3rd party companies to build integrations with their applications.   I would recommend you reach out to Noom to make the request.   Our API support team is available to help Noom with the integration.
In the meantime, I'm moving your post to the Feature Suggestions forum.
Status changed to: Not currently planned
YojanaFitbit
Moderator Alum
Moderator Alum
Thanks for sharing this suggestion. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this suggestion to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly. Thanks for your participation in the Feature Suggestion forums, we look forward to making Fitbit more useful for you.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @KC1953. Thanks for sharing this suggestion about integrating your Noom meals to Fitbit with us. This idea was already requested in the Feature Suggestions board, so I’ve moved your post here. This will help us to keep the forums organized and make sure the suggestions don't get confused, or split a popular vote. Click on the thumbs-up to show your support.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @LindaWU. Thanks for sharing this suggestion about being able to log your food from Noom to Fitbit with us. This idea was already requested in the Feature Suggestions board, so I’ve moved your post here. This will help us to keep the forums organized and make sure the suggestions don't get confused, or split a popular vote. Click on the thumbs-up to show your support.
Nonnyneenee
First Steps
Please enable my Charge 5 to sync my Noom calories and food intake. It does sync my sleep, steps & water
(which I totally appreciate!) but my calories are VERY IMPORTANT to my success in losing weight and my overall health.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Nonnyneenee, thanks for taking the time to share this suggestion about syncing with Noon app. This feature suggestion already exists, so I’ve moved your post here. Click on the thumbs-up to show your support.
While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
I hope to see you around.
