Allow Lap runs lower then 0.5 miles on Versa series
I just purchased the versa and so far I like it except it doesn't have the lap run option. I upgraded from the surge and it had the option that didn't use GPS to count your laps and times while running. You would press the bottom right button and it would count the lap and give you the time. On the versa it can count the lap but the lowest option it gives you is .5 miles and you can't manually do it
4 Comments
Status changed to: Reviewed By Moderator
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Lindsey97, thanks sharing this idea! Your suggestion might be helpful to other users, let's wait and see how people respond.
webgringa
First Steps
I would also like to have the manual lap function on the Versa. 🙂
NickProsser43
First Steps
Please add the option on the exercise app to make 0.25 miles count as a lap. Right now the minimum lap distance is 0.50 miles.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @NickProsser43, thanks for explaining why you would like to have the option to use lap distance lower than 0.5 miles Versa/Ionic. Thanks for sharing your feedback. I've moved it into a similar request.  A lot of users are asking for this option, I hope we receive updates soon.
