Currently, the countdown on the Charge 6 only allows for 59 minutes and 59 seconds. It would be great if the countdown would allow at least 90 minutes (the 59 minutes threshold seems a bit arbitary as you could display 99 minutes as well without having to change the interface).
Moderator Edit: Clarified subject and updated label
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
