Small request as I am trying out the Fitbit App Gallery. I should be able to delete draft apps before they are ever published. I created one just to see what options I was offered, and was unable to remove it after the fact. I will end up using it, but wanted to mention it none the less, for those that create something by mistake.
Thanks for the suggestion @allyann, this is definitely on the roadmap. Checking with the product team to have a better idea about the timeline. In the meantime, if you have any requests about apps or clock faces to delete from GAM, please let us know.
I totally support this idea to remove draft apps. Actually there shouldn't be any need to ask what the community thinks about it, it should be very logical. Thanks
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
