Allow distance units not to determine temperature units
If you set your distance measurement as miles, your weather app is automatically put into Fahrenheit, and if distance is set as kilometres, weather app shows celsius. You should be able to choose one setting without inferring the other.
Moderator Edit: Clarified subject and updated label
1 Comment
Status changed to: Existing Feature
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @MicrobioBec, thanks for participating in Feature Suggestions. We’re happy to let you know that this already exists on the Fitbit app. Your are able to adjust the type of units you want to use for your height, weight, water consumption and temperature. You can find detailed instructions in this help article. Please note that for the Weather app, you need to change the temperature in this app setting as described here. We hope you enjoy this feature and keep adding your suggestions!
