Allow multiple devices on the same account (Sense/Versa series, Inspire, Charge & Luxe)
Be allowed to have both a Fitbit Versa and a Fitbit Ionic on the same account so you can easily switch between them.
Moderator edit: Title & Labels
2,050 Comments
Imagery
Jogger
Users should be able to add multiple devices to their account and choose which one is active at any given time. This gives them the freedom to continue to use all their devices and select different ones for different activities. This would also resolve any syncing issues since only one device would be selected to sync at a time.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @Imagery, thanks for taking the time to share your feedback about the possibility of adding multiple devices to your account and choose which one is active at any given time. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Thank you again for your participation in the Community.
Shutter
Jogger
Please support multiple trackers on the dashboard.
I had an original CHARGE and an IONIC on my Dashboard together but since I upgraded to a SENSE and a CHARGE 5 that is no longer possible. (Why was that feature discontinued?)
DavideFitbit
Moderator Alum
Moderator Alum
Hi @Shutter, thanks for taking the time to share your feedback about the possibility of adding multiple devices to your account/dashboard. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
nadeimy
First Steps
Would like to be able to switch between my Versa 2 and Luxe watches.
zmmetz
First Steps
We need to be able connect multiple devices that use the Fitbit Gallery to one account. I like the sense for day to day activity but want to use the Charge 5 for workouts
DavideFitbit
Moderator Alum
Moderator Alum
Hi @zmmetz, thanks for taking the time to share your feedback about the possibility of adding multiple devices  that use the Fitbit Gallery to one account. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @nadeimy, thanks for taking the time to share this suggestion about being able to connect your Luxe and Versa 2 to the same Fitbit account with us. Because a similar idea was already requested in the Feature Suggestion board, I’ve moved your post here. Please support this idea by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
SabMorningstar
First Steps
I recently bought a Fitbit Luxe and would love to use it as a replacement to the bulky Versa 2. I can only sync one at a time with my account and it makes it annoying to switch. The Luxe is advertised as a tracker. The multi-tracker mode should work with that.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @SabMorningstar, thanks for taking the time to share this suggestion about being able to connect your Luxe and Versa 2 to the same Fitbit account with us. Your feedback is greatly appreciated. This feature suggestion already exists, so I’ve moved your post here.
To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
I hope to see you around.
SeattleAD
Jogger
I have a Fitbit Blaze, Versa 2, and now a Sense. I would like to be able to at least connect the Versa 2 and Sense to thte mobile app so that I can switch if one should run low on memory.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @SeattleAD, thanks for taking the time to share this suggestion about being able to set up your Versa 2 and Sense in the same Fitbit account with us. This idea was already requested in the Feature Suggestion board, so I’ve moved your post here. Please support this idea by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
JRVD
Jogger
Multiple watches able to be installed on one account
DavideFitbit
Moderator Alum
Moderator Alum
Hi @JRVD, thanks for taking the time to share your feedback about the possibility of adding multiple devices to your account. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
deblaunius
First Steps
Requested for several years now ... allow multiple devices on the same account
I'd like to be allowed to have both a Fitbit Sense and a Fitbit Inspire 2 on the same account so I can easily switch between them. I've went through these requests and this seems to be requested for several years now.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @deblaunius, thanks for taking the time to share your feedback about the possibility of adding multiple devices to your account. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Please go back to allowing Fitbit participants to use multiple tracker devices on their account!! It does not make good business sense to limit the trackers on a user's account - you did not use to do this! It would generate more sales, I'm just waiting to replace one of my older trackers but would have to retire them all just to add a new one.
Clinician
Jogger
Yes please!!! Totally agreed!!!!!
Clinician
Jogger
I would also love this feature because I wear the fitbit Sense (honestly prefer the fitbit Versa because everytime I try to do push ups or pull ups,  the senses are activated and it stops my workout....
(Sorry the fitbit survey interrupted!)
Anyway,  my point is,  I would also love this feature because I would like to wear a fitbit during martial arts class but wearing a Sense or Versa tracker/watchwatch is just too big,  I would need something much smaller. I would consider buying another fitbit, one for everyday use, and one for martial arts class,  to safely utilize my fitness tracking devices.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @colleenbreuning, thanks for taking the time to share this suggestion about allowing you to connect multiple Fitbit devices in one account with us. Because this idea was already requested in the Feature Suggestion board, I’ve moved your post hereThis will help us to make sure the suggestions don't get confused, or split a popular vote. Please support this idea by adding your vote.
SunsetRunner
Not applicable
I have a Charge5 and a Sense fitbits When I switch from one to the other it’s a pain having to go through the entire setup process when I decide to switch from one to the other.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @SunsetRunner, thanks for sharing this suggestion about being able to connect multiple devices to your Fitbit account with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. If you haven't done so, please click on the thumbs-up to show your support.
livjorgenson
Jogger
Make it possible to switch between two devices on one account (eg luxe and versa). I would like to use different devices for different purposes. Fitbit would boost sales and customers happier.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @livjorgenson, we wanted to let you know that the idea you recently posted already exists on the Feature Suggestions Board. You can see it here where you can add your vote to that existing suggestion:
Please try to make sure you only post one idea per suggestion, so we can keep the board organized, easily searchable and see which idea other members are voting for. Thanks for participating in Feature Suggestions.
Sabri1255
First Steps
I want to connect 2 fitbit to the same account one as main the other as sub and both sync to the same account
