Allow multiple devices on the same account (Sense/Versa series, Inspire, Charge & Luxe)
Be allowed to have both a Fitbit Versa and a Fitbit Ionic on the same account so you can easily switch between them.
Moderator edit: Title & Labels
2,050 Comments
SunsetRunner
Not applicable
I would like to have more than one fitbit on my account, such as a charge and a Luxe.
mchili
Tempo Runner
I'm about to order the charge 5 but hesitate because of this horrible situation and would love to be able to switch between my numerous Fitbits (Alta hr, charge 2, charge 3, versa and inspire 2) currently I can only have the inspire 2, the Alta hr (which I rarely use) and the charge 2 (which I only use while the inspire 2 is charging)..the versa no longer syncs and the charge 3 screen is not visible outside so they are just collecting dust...  @LizzyFitbit  or any other moderator out there, can you at least give us a yes or no answer and not leave us hanging? And please don't refer me to the original post that has this request since 2014!! Thanks!!
jenhenry
Jogger
So frustrating to see this continuing to be ignored. Has anyone tried complaining about this on Twitter? I'm not on there or else I would. Sometimes companies will respond better to a little social pressure.
mchili
Tempo Runner
I did complain on Twitter but got the standard reply that they will pass the suggestion on to the developers 🙄
LeeW1
Recovery Runner
EVERYONE should complain on twitter.  NO ONE outside of this forum sees these frustrated comments here.  POST TO TWITTER and at least they are publicly visible to anyone browsing the Fitbit feed.  Once you've been redirected here, I strongly encourage EVERYONE to then post to twitter.  Make enough noise there and maybe we'll get a real answer.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @SunsetRunner, thanks for sharing this suggestion about setting up more than one Fitbit device to the same account with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
LindsayC85
First Steps
I am so mad to see that the same problem has existed since 2013 & all the complaints on the forum being ignored & brushed off! This box isn’t even big enough for me to detail the problem - says it all really!
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @LindsayC85, thanks for sharing your feedback about allowing multiple devices on the same accountWe‘re taking your comments and sentiments in regards to our products and services into consideration. I've moved it into a similar suggestion which has been updated as "Under Consideration". To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
 I hope to see you around.
Sam8max
First Steps
Allow inspire 2 and versa 3 to link and be used interchangeably
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Sam8max, thanks for sharing this suggestion about being able to connect the Inspire 2 and Versa 3 into the same account with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
CoachB67
Jogger
The IOS app only allows one unit to be registered to a user, which means that switching unit entails fully "initial setup" of new unit into the app/account. Enabling several units registered will allow me, as a user, to have one unit for specific activities.
Status changed to: Reviewed By Moderator
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @CoachB67, we wanted to let you know that the ideas you recently posted already exist on the Feature Suggestions Board.  I've moved one into a similar request. You can see the second one here, where you can add your vote to this existing suggestion:
Please try to make sure you only post one idea per suggestion, so we can keep the board organized, easily searchable and see which idea other members are voting for. Thanks for participating in Feature Suggestions.
Guy_
Space Racer
HI @CoachB67 -  there is another approach.
It is to have 2 accounts [even if not ideal] - you simply logout of one and login the other. Works well with a Versa and a Sense. You also get a pair and link popup, if you head to the home screen without closing the app. This ensures you get connected quickly.
If you adopt this approach install the SimpleCheckUp app. This will tell you directly on the watch when you last synced  and if its connecting to the Fitbit App, so you don't need to get your phone out. It reminds you when to sync so you don't lose data [about 5 days for a Versa if used simply]
JamesA78
Stepping Up
I previously ran a Charge 2 and a Sense device side by side without issue, switching depending on the use (eg. some sporting activites it was safer to use the smaller Charge form factor than a large screened watch). I purchased a Charge 4 to add dedicated gps tracking. Now I have to set up each device (notifications, etc) every time I switch.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @JamesA78, thanks for taking the time to share your feedback about the possibility of having other devices on the same account, particularly the Sense and the Charge 4. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Thank you again for your participation in the Community.
Laylath
First Steps
I liked having 2 trackers a sense for every day life and a charge 2 for work (incase my roughy life broke it)
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Laylath, thanks for taking the time to share this suggestion about allowing multiple devices on the same account. I've moved it into a similar suggestion which has been updated as "Under Consideration". To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
cgrebert
Jogger
The title says it, really. It is not currently possible to add more than one fitbit to the account if they both use the gallery (in other words, all fairly recent fitbits).
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @cgrebert, thanks for sharing this suggestion about being able to set up multiple devices that share the Fitbit App Gallery on the same account with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
VinceFF
Jogger
Hello-
I have been a Fitbit customer for more than 6 years.
I would like to buy a Charge 5 but also want to keep using my Fitbit Ionic.
This appears to be impossible because when I try to add a "Charge 5" to my account, it does not allow both - it only allows me to switch to the new device.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @VinceFF, thanks for taking the time to share your feedback about the possibility of allowing more than one device on the same account. As you mentioned earlier, you can't connect multiple devices that use the Fitbit Gallery to one account. For Fitbit Charge 3, Fitbit Charge 4, Fitbit Charge 5, Fitbit Ionic, Fitbit Inspire series, Fitbit Luxe, Fitbit Sense, and Fitbit Versa series, only connect one of these devices to your account at a time.
Thank you again for your participation in the Community!
xlr8ight
First Steps
I'd like to see the ability to link more than one "Gallery Enabled" Fitbit. I'm not sure why having apps support limits us to one device per account, and most new models are all Gallery enabled.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @xlr8ight, thanks for taking the time to share your feedback about the possibility of using more devices with App Gallery on the same account. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
JamesA78
Stepping Up
It would appear fitbit has been working on "adding this support" since 2014, but has failed to deliver this feature while releasing multiple new products.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @JamesA78, thanks for sharing this suggestion about having more than one device sharing the App Gallery connected into the same Fitbit account with us. This idea was already requested in the Feature Suggestions board, so I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. We truly appreciate your feedback and we'll keep tracking this request over time, so please click on the thumbs-up to show your support.
