Currently the Charge 3 does not give a detailed sleep pattern (REM, light, deep) if you do not sleep for three hours initially. Apparently this is in the manual but was not in the informational material that I checked before buying the tracker. This makes it unusable for those of us who bought the Charge 3 as a sleep monitor as we have problems sleeping. I have only been able to get detailed tracking for 3 nights out of 8. Is there a software fix that could reduce the length of this initial requirement?
Moderator Edit: Clarified subject and updated label
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
