Makes sense. This is a great request @ashishkulkarni, I'm sure other Aria users would like this as well. I will forward your request to our developers and hopefully they implement this in the near future.
Any other ideas you might have, feel free to share or vote for them, if it’s already suggested in the Feature Request Forum. Thank you!
I think there are more things to worry about than seeing fractions of a pound
its not the point.... other scales weigh in decimal points and this scale does weigh on the website in decimal points so it should display the same on the scale as it does online
I think adding a decimal place for pounds on the display of this size will clutter the scrolling info. If you're that concerned about a 10th of a pound, as you say, there is the website. Just my thinking 🙂
It is accurate, just not displaying the minutia. It's a bit like a watch not displaying tenths of seconds; it's still accurate but I don't need to know it in everyday day life. But as you say, each to his own.
I wouldn't mind so much that the display only shows the nearest pound if the rounding was accurate. But having the scales show that I weigh 9st 8lbs when the dashboard shows it is actually 9st 8.8lbs - it seems obvious that the scale display should round up rather than down?
I would be happier either with the display showing the nearest 0.1lb or fix the rounding on the scales to be accurate.
This has to do with your app. Until the last update, the Log Weight showed to the 1 decimal point for both weight and fat %. I really appreciated this feature. After the last update, only the fat % shows to the 1 decimal point; weight is rounded. I do not like this change. I would very much like this feature to be re-instated. The lose of this feature will impact the graphs for both Weight and Lean vs Fat. There is a difference between 115.9 and 115.1 pounds in weight.
This was first looked at by a moderator in 2015. Come on FITBIT, This is ridiculous. Paying £100 for a set of scales that don't tell you your correct weight. the scales need to have a decimal point so that it is the same as the dashboard information. This cannot be too hard to sort out. Come on!
The weight history shows the weight in stones and pounds but the graph shows the weight as a decimal which obviously gives slightly different figures for each. Please allow the graph to show weight as stones and pounds.
There is no facility on the Android app to enable users to enter a decimal point when entering their weight. This means weight has to be rounded to the nearest lb and therefore doesn't give an accurate reading. Surely this feature could be added without any difficulty.
26.1 on the most recent dot/point in the Weight/Lean-Mass chart (www.fitbit.com/weight)
Within the cronometer.com, this weight log from today is shown *more accurately* as:
25.9
(I have added cronometer as a synced Application via my account settings)
It's quite unfortunate that cronometer.com shows more accurate representations of my actual weight logs than fitbit.com does.
I suspect the 25.9 displayed by my fitbit Aria actually has two decimal places and is quite close to 26.0 and has been rounded up for the display of my weight log entries at fitbit.com/weight.
However I cannot explain why it is displayed as 26.1 on the chart on the same page.
(There is only one weight log entry for today, so the chart value is not an average of multiple values, and should be using the same value as the weight log entry).
If the Aria is uploading figures with two decimal places, I would like to be able to see those within the web site and hopefully in any data export.
Hi everyone, and thanks so much for sharing this suggestion! While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visitour FAQs. We're always striving to enhance Fitbit products and services, and your input is a big part of that process. We truly thank you for taking the time to share your feedback with us.
Sometimes my aria air does not connect so I enter my weight manually. However i can never enter to the exact decimal which is important to me as any weight loss is important
Hi @Garyjnrwilliams, thanks for explaining why you would like to have the option to add decimal point to enter weight on Aria Scales. This feature suggestion already exists, so I’ve moved your post here. While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
