Better music controls
I find my new blaze to be trying to "connect." Then "load music..." Counlessly when I am just trying to gain easy access of hitting a fast forward or pause button I would find it most benifitial if I could easily do this via fitbit rather than opening my phone or buying hundreds of songs I have randomly generated for me I am currently using LG Stylo 3 and am not sure if it is due to my phone model that fitbit needs to correct or fitbits incompetence to understand peoples basic wants to listen to music through different platforms... Sensierly dissatisfied for buying such a expensive piece that doesn't perform properly sorry if someone posted something similar please leave link if so. Thank you
Moderator Edit: Updated Title for Clarity/Added Labels
1 Comment
Status changed to: Existing Feature
EdsonFitbit
Fitbit Moderator
Fitbit Moderator
Thanks for your suggestion and for your feedback. Unfortunately, the LG Stylo 3 is not part of the list of compatible devices. If you have a compatible device please test Music Control to see if it's working fine. If you need assistance please contact Customer Support.
