Early Warning & SOS Alerts for Heart Attacks (or other health issues)
Research indicates (refer to links below) that it is possible to detect potential Heart Attack based on Heart Rate and Heart Rate zones. Fitbit watches constantly monitor heart rate and theoretically it should be possible to detect potential heart attack based on abnormal heart rate and resting heart rate's trend.
  1. Emergency SOS: Fitbit device should trigger alert on paired mobile phone which sends out a SOS message along with geo-location to pre-configured address to ensure timely medical assistance.
  2. Preventive Alert: Fitbit should alert the user if it sense potential Heart Attack based on current & resting heart rate patterns or change to a different heart rate zone.
Reference:
Moderator Edit: Added Labels
157 Comments
bardic
First Steps
@DavideFitbit my apologies! I didn't see it when I did my initial search to see if the suggestion has already been made. Thank you for moving it.
TheLeroyMan
First Steps
Many folks would like to have a warning if their heart rate is too high, it would be excellent if there was such a feature, especially for those with heart issues. I think companies don't want the culpability (or the regulation) of the medical device mfg. community, but FitBit could easily do this, and it would help.
I have seen posts for FitBits for the elderly or infirm, and features like notifications for low/high heart rates, long term data on how sedentary folks are or heart rate or sleep would be tremendously helpful.
A FitBit that just connected to WiFi would also alleviate the need for a close proximity cell phone, and could be used in nursing homes, for live-in parents, or folks who want to live alone but need an extra eye every now and then when things go wrong.
Make this device! (And send me and my family part of the profit!)
DavideFitbit
Moderator Alum
Moderator Alum
Hi @TheLeroyMan, thanks for taking the time to share your feedback about having a High Heart Rate Warning, this feature suggestion already exists so I’ve moved your post here as it is currently under "Reviewed by moderator" status. This helps maintain the Community and the Feature Suggestion board more organized.
DavideFitbit
Moderator Alum
Moderator Alum
No problem at all @bardic, thank you for sharing your feedback and ideas in the Community! 😀
rusa007
First Steps
4 years since the suggestion... yet none of the trackers have this options 😐
Rich_Laue
Community Legend
Because none of the travelers have been certified by the FTC for this. 4 years ago the technology needed did not even exist, and it is only into Fitbit OS came out that it might be possible.
We would be asking Fitbit to look at blood flow in the wrist and tell us what the electrical signals going to the heart look like.
ener64
First Steps
no feature yet where the device will alarm if heart rate data reaches high or low level, I mean people die in their sleep. have it so you set the alarm on the internet and the alarm goes out to 10 numbers that you pick, then a voice call from the device comes on cause you may not be able to speak. so the watch does it for you.
Temp would be cool tool.
I mean their is no watch for seniors.
Yet at the same time it does not matter weather it should be for seniors or not, everyone is at risk at one point to die.
and the alarm should be on every  watch.
Rich_Laue
Community Legend
This would not be something that could just be added, but like the SpO2 sensor needs approval, maybe in each country before it could be turned on.
But how would the tracker determine a heart attack. You could not go by lack of heart rate since many have found nights with large gaps in their reading.
As for I high level, their was a recent beta test for this.
ener64
First Steps
far off to predict a heart attack but you can senor it if heart gets too high or too low. and then is set manually.
Ric323
Jogger
Yes. You don't have to call it a "heart attack" warning.
Just let the user nominate a min and max value to count as "normal", and trigger an alarm if it goes outside that range.
BrianThompsons
First Steps
I think this may save lives. I want Fitbit to make a heart rate monitor, with GPS, that can sound an alarm to emergency services if the heart rate gets too low or stops. This device needs an 8-12 hour battery. This could also notify a family member, who could call the person to check up, before emergency services are called, to not waist resources.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @BrianThompsons, thanks for explaining why you would like to have the option to use early warning and SOS alerts for heart attacks. Thanks for sharing your feedback. I've moved it into a similar request.  A lot of users are asking for this option, I hope we receive updates soon.
gtoto1961
Jogger
I sort of started this thread about the heart rate a awhile back. I see that you are coming out with Versa3 that will be able to do some of the things needed. I was just hoping it would be more affordable.I have the Versa 2 and I had to do it in payments to afford it. Plus you charge extra for the added items
KFK15
Jogger
My Garmin had an alert which I could set - in my case if my heart rate is above 110 on my resting moment - and it would alert me. Very good and I would clearly be informed when I was getting stressed in a meeting. Was very useful. I don't have that on Charge 4. When is this going to be implemented?
Grizzly77
First Steps
I would like to like fitbit to notify me when my heart rate gets to a selected BPM.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Grizzly77, thanks for explaining why you would like to have the option to see Heart Rate notifications on specific ranges. Thanks for sharing your feedback. I've moved it into a similar request.  A lot of users are asking for this option, I hope we receive updates soon.
flroots
Base Runner
For the Sense, provide notification for irregular heart beat in addition to low and high heart beat.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @flroots, thanks for explaining why you would like to have the option to see early warning and SOS alerts for heart attacks (or other health issues). Thanks for sharing your feedback. I've moved it into a similar request.  A lot of users are asking for this option, I hope we receive updates soon.
LxPeanut
Recovery Runner
The ability to set it to vibrate when heart rate goes above a set level without being in exercise modes. This needs to be customisable so you can set your own level and preferably have a setting to alarm until the heart rate drops again.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @LxPeanut, thanks for explaining why you would like to have the option to receive early warning alerts for Heart Attacks or other health issues. Thanks for sharing your feedback. I've moved it into a similar request.  A lot of users are asking for this option, I hope we receive updates soon.
Arcflash
First Steps
I would like to be able to set a heart rate zone and have my FitBit vibrate whenever my heart rate leaves that zone. I would use this all day (not just during exercise) to warn myself if my heart rate is above a pre-determined level.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Arcflash , thanks for explaining why you would like to have the option to receive alert notification during the day, when heart rate leaves an specific zone. I've moved it into a similar request. I think that a lot of users would like to have this option on their Fitbit devices.You can learn more about how Fitbit decides what suggestions get released in our FAQs.
Karl80
Stepping Up
Too bad it is not even under consideration yet.
shentz86
First Steps
- detects if there’s something wrong (Dangerous BP levels, heart stops) and gets ahold of 911
- starts with a warning/vibration in case it’s just sitting on the wrist wrong
- attach an emergency contact
- can track your heart rate, when you sleep, and even if it’s not on your wrist
-Better than life alert, there’s no button to push accidentally
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @shentz86, we wanted to let you know that the ideas you recently posted already exist on the Feature Suggestions Board. You can see them here where you can add your vote to those existing suggestions:
Add an SOS function to text emergency contact
ICE - In Case of Emergency
Please try to make sure you only post one idea per suggestion, so we can keep the board organized, easily searchable and see which idea other members are voting for. Thanks for participating in Feature Suggestions.
