Currently, it doesn't seem possible to link my fitbit and Garmin connect account in such a way that the numbers from my weigh-ins (such as weight and fat%) are automitically imported in Garmin Connect. At the moment, this should be done manually... Would definitely be an added value to have this done automatically behind the scenes...
You have to create a myfitpal account and synch Fitbit to it. Then sync your Gain account to your myfitpal account. It's a workaround that's effective.
I posted on a different thread but I figured I would post here as well - I've developed an app for syncing your weight from Fitbit to Garmin Connect. It's not free but I'm hoping it's not too much, it helps ensure I'm able to maintain the project going forwards.
Hi everyone, and thanks so much for sharing this suggestion! While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visitour FAQs. We're always striving to enhance Fitbit products and services, and your input is a big part of that process. We truly thank you for taking the time to share your feedback with us.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
