I agree. I have had my Fitbit Ionic for a few months now, and I have enjoyed using it for the basic functions. I recently bought Bluetooth headphones and attempted to connect to transfer music. After getting very frustrated and reviewing many forums, I figured out Ionic does not connect to the type of Wifi network I have. I do not understand how such a high-end, expensive watch does not have the ability to connect to a type of network that is so common. It is very aggravating to have spent so much on a watch that I now discover I will not be able to use from the comfort of my home!!
5 GHz WiFi would be cool, but alongside Europe you'll have most WiFi networks in the 2.4 GHz Band. If you consider to add 5GHz support be aware, that supporting the 2.4GHz Band would be nessesary, too.
5 GHz is a must nowadays. Personally, I was planning to shut down my 2.4 GHz network and go 5 GHz only, but because of my Fitbit Scala I cannot do that, sigh.
The next time I go shopping for a WLAN enabled appliance, I will definitely look for a device with support for 5 GHz.
Yes, 5g needs to be added. I'm about to ditch Fitbit for good and go with a smartwatch that will connect smoothly with my android phone and 5g connection. It's frustrating to have to switch back and forth between the 2.4 and 5 just for the Fitbit.
Like most smart devices Fitbit use 2.4GHz bandwidth, to connect to WI-FI. The majority do not know how to force smartphones to connect to the 2.4 GHz band. Bluetooth 5.0 transfer data with 2 MB per second. 2MB is enough for a tracker or smartwatch.
Hi @LokeAa, thanks for explaining why you would like to have the option to connect using 5 GHz Wifi or just Bluetooth. I've moved it into a similar request. I think that a lot of users would like to have this option on their Fitbit devices. You can learn more about how Fitbit decides what suggestions get released in our FAQs.
Thank you again for your participation in the Feature Suggestions Forums.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
