For about 10 years FitBit goes through phases of adding manual reading. Either give an option to not have any manual readings or fix this, as after 10 years of often having to clear these out I’m pretty done with FitBit and being suggested to do a resume that does nothing. It’s a known issue, so give a proper solution. I have no connected apps
I feel your frustration manual readings piling up can be really annoying. A workaround I’ve found helpful is using sync and data-cleanup tools, and some guides on managing this efficiently are available on Ostora TV pc.
