I'd like the ability to design a clock face without having to know or learn programming. An Android app to design clock faces would be nice. I see that there are Android apps out there for other smart watch manufacturers.
Right now you can use the Photograph clock face that let you customize it by using your own photos or images. If you want to achieve something more complex, one developer created the Maker clock face that let you do what you are looking for.
A number of the clock face designs currently available offer limited options for changing the values displayed and their positioning on the screen. Creating an application or additional feature of the Fitbit app that allows users to customise their clock faces to their desired style using tiles that can be positioned on a virtual clock screen.
Hi @05ballardb, thanks for explaining why you would like to have the option to create clock faces for Fitbit devices. Thanks for sharing your feedback. I've moved it into a similar request. You can also check this other suggestion: Versa WYSIWYG Clock Face Creator.
A lot of users are asking for this option, I hope we receive updates soon.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
