- You need to find a better way to connect the band to the fitbit lux. I bought one and have had nothing but issues with the band falling off because the little plastic clip is not strong enough to hold the metal band that comes with the fitbit. You wear the band on regular day and band comes apart front the face and fitbit falls off and then it will get lost. You need to develop a better way to attach the band other than a little piece of plastic
Moderator Edit: Clarified subject and updated label
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
