how about you make a new fitbit called the "fitbit pen" and it is a steps tracker but is also disguised as a pen and the button on the top can set you into sleep mode if held down for 3 seconds and will flash a light when it is enterd and exited and if you just press it it will show your steps and is charged with a divice you guys have put in it kind of like the flex you would take it out by opening the writeing part of the pen (the pointy area on all pens) and would be carryed around in your pocket or on your shirt pocket like any other pen and you would tap on it with the button on the top of the pen
it will be cool, no one will knwo 🙂
just make sure you put "Fitbit" on it, i may mistake it for my real pens
Moderator Edit: Clarified subject, updated label and personal info removed
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
