Make phone calls on the Sense series
I had a fitbit blaze, i loved it, had for a couple of years then my husband bought me galaxy watch, it needs charging everyday, sposed to be every 4 but the point of this is that my fitbit blaze is still going strong as I passed it on to my daughter and she loves it also, the only reason I changed was the facility to answer the phone on the watc
63 Comments
jvuser
First Steps
This would be very useful for calling 911, in case of a fall, where I could not reach my phone to make the call.   Providing this feature would let the watch serve as an emergency alert type of device.
NituG
First Steps
I would also like the feature enabled to allow access to your contacts stored on your phone and be able to make outgoing calls to them and or text message from fitbit sense
Currently I can answer an incoming call through my fitbit sense and talk through the watch. However if I initiate an outgoing call, it goes through my phone. I want to be able to initiate the call with my watch and talk with my watch like I do on incoming calls. I don't want to pull my phone out
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Trademarkman23, thanks for sharing this suggestion about being able to make phone calls directly from your Fitbit device with us. Because this idea was already requested in the Feature Suggestions board, I’ve moved your post here. This will help us to make sure the suggestions don't get confused, or split a popular vote. Please click on the thumbs-up to show your support.
Saheli_Sen
Jogger
After making calls through Google assistant, it is redirected to the phone. Can't talk through watch after making calls. Need this feature to talk over the phone and making calls from the watch. Also, it will be great if the call notifications will come from other apps like WhatsApp, Facebook, Instagram. So, that we can answer through the watch.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @Saheli_Sen, thanks for explaining why you would like to have the option to make phone calls on the Sense. I've moved it into a similar request. I think that a lot of users would like to have this option on their Fitbit devices. You can learn more about how Fitbit decides what suggestions get released in our FAQs.
Thank you again for your participation in the Feature Suggestions Forums.
CurtFB
First Steps
Can you also add the ability to make calls within the SDK for applications and clock faces?
petq
Jogger
Would love the ability to make phone calls from the sense
Nandor
Runner
I also support to make possible calls from versa3/fitbit sense. As in some counries (for example Hungary) unfortunately google assistant is not available,  a contact list app with the possibility to sync the phonebook list would be the best solution for all. Or please make possible everywhere google search and the other options on these and other watches/trackers what we dont have here!
Thank you
giri210995
Jogger
Dedicated Phone app to type and call number.
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @giri210995, thanks for sharing your feedback with us. We wanted to let you know that these ideas already exist on the Feature Suggestions Board. You can see them here where you can add your vote to those existing suggestions:
Please try to make sure you only post one idea per suggestion, so we can keep the board organized, easily searchable and see which idea other members are voting for. Thanks for participating in Feature Suggestions.
alexandre.petre
Recovery Runner
The ability to call can be very useful in particular context, e.g. when skiing.
You don’t want to be forced grabbing your phone out of your pockets in this case. Calling from Sense is much easier especially when being on the chair lift.
sses8413
First Steps
Making outgoing calls is very important for fitbit users when we are out for a run or even a walk and there is an emergency or something very important going on that people is trying to get ahold of us when the situation can't wait any longer we should be able to take calls, and make calls from our watch.
DavideFitbit
Moderator Alum
Moderator Alum
Hi @sses8413, thanks for taking the time to share your feedback about being able to make outgoing calls from the Fitbit Sense. I noticed that a similar feature suggestion already exists, so I’ve moved your post here, this helps to keeps the boards more organized. Make sure to add your vote as well to support this suggestion, this helps the team of developers to keep track of popularity and demand over time.
Thank you again for your participation in the Community.
IshankaM
First Steps
Can you add making phone calls with fitbit sense?
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @IshankaM, thanks for taking the time to share this suggestion about being able to make calls directly from your Sense with us. I noticed that a similar idea was already requested in the Feature Suggestion board, so I’ve moved your post here. Please support this idea by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
Piglet90
First Steps
Qe need an update to enable Sense to make calls. I can use Google Assisitant to dial and make a call but the microphone that allows me to receive calls doesn't work to let me speak on outgoing call but does in incoming calls? Why is this only a one way feature?? Please add an update to enable this feature. Such a simple thing should be available
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @Piglet90, thanks for taking the time to share this suggestion about being able to make phone calls on the Sense with us. Because this idea was already requested in the Feature Suggestion board, I’ve moved your post here. Please support this idea by adding your vote, this helps our developers to keep tracking its popularity and demand over time.
Piglet90
First Steps
YES PLEASE
AKARAS
Recovery Runner
Please allow mic to work for outgoing calls
LZeeW
Space Racer
Your competitors have this feature.
AKARAS
Recovery Runner
Had an emergency, was locked out of car. Phone was in car, being able to make phone call from Sense since I was in fact near the phone would have been a life saver. Needless to say that feature is not available. If mic is available for incoming calls it's silly that it's not for outgoing. One day it could be a matter of life and death for someone.
0 Votes
Rich_Laue
Community Legend
This is a duplicate of Make Calls On The Sense
 This suggestion should be merged with the existing suggestion.
AKARAS
Recovery Runner
Not too familiar with all community post areas and features. Just trying to get it out there as much as I can for fitbit to notice, lol hence duplicate.
Rich_Laue
Community Legend
But having it split, also splits the votes, and then neither will get the attention.
We really need.. 25+ votes a month.
