More Accurate Battery Life or % in Mobile App
I have owned a Fitbit Charge HR for about 2.5 weeks now. Using the battery life indicator icon on the dashboard on my iPhone or IPad, I was shocked to see that I was at one-half reserve or less by the second day after full charge. I have no notifications permitted and only sync when I open the apps ( few times in 24 hours.) When I plugged in the Fitbit to recharge, however, the battery reserve always showed much greater than the dashboard icon reported. "What gives?" I asked. So, today I called your trusty tech support staff who has just confirmed that the battery life icon on the dashboard only has three "levels" it can report: full, medium, and low. Hmmmm. Not so cool.
OK, guys, please revise your onboard firmware and app software to more accurately reflect the true status of the battery reserve when checking into the dashboard. The "new dashboard" graphics have not addressed this issue. Otherwise, a lot of folks are going to be charging their devices unnecessarily rather than tracking all the fun on wrist or ankle, where they belong. Thanks!
Moderator edit: Labels.
345 Comments
DJRich
Jogger
Have now swapped to an Ionic which i can see the messages and time clearer and it has a battery percentage level on it.
It also emailed me when the battery was flat! again very useful when i get loads of emails and don't check regally! why not just get the watch to tell you?
bvicente
First Steps
Question is, why can't Fitbit simply modify the software to show battery
percentage level on Charge 2?
SunsetRunner
Not applicable
@DJRich the easy answer is: too expensive
Status changed to: Under Consideration
EdsonFitbit
Fitbit Moderator
Fitbit Moderator
Hi everyone thanks for sharing this suggestion. This is being discussed although I do not have a firm commitment or timeline at the moment. Do continue to vote for this feature suggestion whilst it’s under consideration.
Please note that if something is under consideration and chosen for development, it can be a while until it's released or until I have any news to share. Please watch this space for any updates! Thanks for your patience.
karinagw
Base Runner
cc:
I really can't wait for the Fitbit development team to get old. Then, you won't be as cavalier about your users not being able to see that ridiculous battery icon on the Blaze.
Time to start looking for a different device. #disappointed.
SunsetRunner
Not applicable
I understand there are variations on this already, but my experience is with a Flex 2 which does not have a screen.
I know for a fact that the battery % is "known" .. I know this because my original flex 2 would not charge fully, and when I contacted support, that asked me to sync my flex 2 to my android phone, and afterwards informed me that the battery was stuck at 90%. When I contacted them the following day they could see that the battery had discharged to 10% in a matter of a few hours.
So ... if the % is available, why can't you display it in the app?
I've continued to run my flex 2 for the best part of a day, even though app said "battery empty" .. knowing the % would be useful to know exactly when to recharge it.
Surely a simple change to the app?
I'm sure people will say that the percentage in app will only be accurate at the point of sync ... but that's fine by me ... if I want to know the %, I'll kick off a sync.
spotter9
First Steps
Hi
It would be much better if there was a battery percentage rather than empty, low, medium, full etc.
I use a flex 2 so the app is handy for knowing exactly how charged my device is and if it is fully charged rather than being 90+% charged and not actually full.
Thanks
Saheza
First Steps
It would be great to have a battery percentage on the Blaze as others Fitbit have! Why is not on the making yet ?!!😳
Kristie1993
Recovery Runner
Show battery percentage rather than the description of low/medium/full
lorivega
First Steps
I had the Fitbit Blaze and I was able to select the option to at least see the battery bar on the screen when I wake it up. I just updated my watch to the Fitbit Versa. I wish that I could see the battery percentage on the screen when I wake it up without having to swipe up.
bvicente
First Steps
Fit says this is not a software fix. I don't quite understand that. I
really hope they someday get the battery percentage. Love the watch
otherwise.
SunsetRunner
Not applicable
Showing battery percentage in the App.
JetK
First Steps
Instead of full medium and empty, use percentage, also on the tracker itself.
LizFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @killerloopz and everyone, I just wanted to affirm that this is on our radar and we've run into a few technical issues with this but it is being worked on. I do not have a firm timeline at the moment but will update this thread when I do. Please continue to vote for this feature suggestion whilst it’s under consideration. Please watch this space for any updates! Thanks for your patience.
SunsetRunner
Not applicable
Yes please. If my old dumb brick phone could display battery % 15 years ago, Fitbit should be able to do this in 2018...
ClintonHammond
Base Runner
Is it possible, instead of the Charge Bar that changes colour,  can the app be tweaked to display Battery Charge as a percentage?
ccgreen
Recovery Runner
The bar would be helpful since there is no warning on how low it goes. Ideally - on the Charge 3 itself.
JaduMindTrick
First Steps
To see the battery percentage on the charge 3 device itself, just swipe up from the home screen and you'll see it in the top left hand corner as a percentage.  Hope that helps.
MarcelBK
Premium User
Moderator Alum
Moderator Alum
Hey @ClintonHammond! Thank you for sharing your suggestion. This idea already exists, so I moved your suggestion here. Do not forget to give kudos by clicking on the thumbs up button.
nijave
First Steps
If you query the Fitbit API directly you get battery % in increments of 10 so this already partially exists but no one has bothered to put this number in the app on Fitbit display
Torakaru
Base Runner
Yes, and also in the Alta HR, please.
franc69
Base Runner
Same for Fitbit Charge 3 - We NEED to be able to see the battery percentage left on the fitbit app. instead of only showing full, medium, etc...
SunsetRunner
Not applicable
Please can you put battery percentages on the app and not just the icon. Thanks
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @SunsetRunner, thanks for explaining why you would like to have this option. I've moved it into a similar suggestion which has a lot of votes. As the more votes and comments an idea has the more visibility and momentum it gains. You can learn more about how Fitbit decides what suggestions get released in our FAQs.
SunsetRunner
Not applicable
I would like to see the battery percentage of my fitbit charge 3 in the mobile app. Some information on how long the battery lasted would also be helpful. I
