Option to track short naps to see analysis
I think there should be a power nap option so if i want to sleep for ten or twenty minutes or so, my Fitbit will detect when I fall asleep and set a silent alarm to go off automatically at the end of the nap
Moderator edit: updated subject for clarity and labels.
100 Comments
MikeCZ
Recovery Runner
Thanks David for the info.
Yes, I will now finish my 1000 days with Fitbit Charge HR and then switch to Garmin.
Marva
Stepping Up
I love the idea of the smart alarm. I'm always waking up tired in the morning even though I get 7-10 hours sleep on average every night. I'm never sure if I'm sleeping too much or not enough. A water proof tracker so it's more versatile for activities like swimming and shower dancing, ha ha! I really love that you have put the waterproof feature in the new Ionic, but I'm waiting for the price to come down a bit and any kinks to be worked out that may arise with the first launch.
Thanks for listening!
Marva
Rich_Laue
Community Legend
Smart alarms are all ready requested waiting for your vote.
I'm at a loss to understand the power nap thing,
Please Remember that adding two unrelated suggestions, as requested,, only adds confusion since there is no way to know which is being voted for.
LizFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @DavidInNTexas thanks for the feedback. We do have some water resistant trackers available; you can compare features here: www.fitbit.com/compare
Status changed to: Reviewed By Moderator
LizFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @nicolosponziell thanks for sharing your suggestions. There is a well established discussion here about smart alarms which you can vote on already.
With regards to power naps, can you elaborate? Do you want Fitbit to suggest a nap based on your sleep data? Please expand.
FYI, there are currently no plans to track naps (or anything >3 hours sleep) as per this suggestion.
Thanks!
KentuckyGardenB
First Steps
There are 161 votes for for the suggestion about tracking short naps but mostly to do with being able to set an alarm to wake on after a short nap. I think that asking for an alarm feature is not the way to go, that's what alarm clocks or the alarm or times features in smart phones are great at. Fit Bit's strength is its accelerometer that can track sleep and software protocols that link that to heart rate to track sleep stages.
In general long naps are discouraged by sleep specialists. Up to an hour is OK.
At present the Fit Bit Alta HR information says that naps will be tracked if more than an hour. But they are not tracked if less than that. I suggest that the algorithm be changed to tracking if  the nap is more than 20 minutes or 1/2 hour. For some people naps may well be an important piece of one's overall sleep profile and Fit Bit should be tracking these. My old FitBit Alta did this nicely. Someone changed the protocol and I don't like it.
geez
Jogger
Sometimes I sleep 10 minutes. I want this captured. I thought I read it captures above 30 minutes sleep, but I am not sure.
Status changed to: Not currently planned
DavideFitbit
Moderator Alum
Moderator Alum
Hi @KentuckyGardenB,  thanks for sharing this suggestion.
We're always striving to enhance Fitbit products and services, and we appreciate all of the input we receive from our customers. We do not currently have plans to release this feature. You can learn more about how Fitbit decides what suggestions get released in our FAQsFor now, we will leave this suggestion open for votes (and closed to comments) so that we can continue to track community demand over time.
Thanks for taking the time to share your feedback with us and we will let you know if anything changes.
manuel.kid
First Steps
So I like to take at least a nap daily and the times varies depending of my schedule. I wonder if Fitbit can implement a setting for Naps called Nap Mode or something else. That you select the Time for the perfect nap and then it will keep track of your sleep (Asleep) once you achieve the rest period of your choice and finally the silent alarm goes off.
Because you can Schedule a 30 min nap but you really end up sleeping less for the simple fact that you body need to fall a sleep.
Firehaas
First Steps
How about a little section on the app to add sleep notes? That way if the fit bit doesn't accurately track a nap, or if you had to much alcohol, or whatever, you can find trends in sleeping patterns.
niceguy44
Recovery Runner
Create the ability for us to tell the Fitbit when we are taking a nap so that time is added to the "sleep" amount for the day.  That would you to take a two hour nap in the afternoon and have it 1) count towards your sleep and 2) not make it look like you were just lazy.  As it stands, Fitbit doesn't count it as sleep unless it is 3 hours, which is longer than my naps.
ColombeDor
First Steps
I noticed my Alta doesnt pick up when I nap, it also doesnt pick up how much I sleep when
Im on a flight. I have worn my Alta on several flights to see how much I sleep and it doesnt gather
any information.
Status changed to: New
AlexandraFitbit
Premium User
Moderator Alum
Moderator Alum
Hi @ColombeDor! Thanks for sharing this suggestion, I moved it to this similar post so you can add your vote to it. Please keep sharing your ideas with us! Woman Happy
AnamaAl
First Steps
Siestas or naps look too odd on the regular sleep graph. It would be great to have a siesta individual graph. 10 - 20 min naps are healthy and would be nice to keep track of them. Also, it seems you have to take a long nap for it to be recognized by the device, would it be possible to change this?
I noticed that sometimes when I remove the device it automatically recognizes sleep, it would be useful to be able to "pause" the device for a couple of hours.
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @AnamaAl, thanks for taking the time to share your feedback with us,this feature suggestion already exists so I’ve moved your post here as it is not currently planned. Thanks for your understanding, I hope to see you around.
KevWip
Recovery Runner
Hello,
Early fitness tracker had an awesome function called "power nap". A user would define his or her ideal power nap time between 15 to 30min and the fitness tracker would measure when the user falls asleep and then wake the user according to previously set power nap time.
This is very useful as it prevents users from falling into deep sleep while napping. It also allows users to easily wake up from the nap and prevents disrupting the sleep cycle entirely.
Could you please please implement that on the charge 3?
Thank you
Jan89
Base Runner
Couldn't you use the timer for that use case? Set the tonet to whatever duration and just close your eyes 😉
KevWip
Recovery Runner
A timer cannot calculate when you are falling a sleep and kick of the power nap time. Also it would not record that sleep boost in your profile.
OhThatTodd
Recovery Runner
This is exactly the fester I came to request. A nap/meditation tracker. That way you get some heart rate data and sleep data as well as not interfering with your activity monitor. Great idea.
AlexandraFitbit
Premium User
Moderator Alum
Moderator Alum
 Nice suggestion, thanks for sharing @KevWip. We look forward to hearing what other community members think. Smiley Wink
SunsetRunner
Not applicable
I tried using the timer function for a quick nap. But in the middle of my nap, a weather notification buzzed, and woke me up!
A nap function would be good, with an added feature to stop your notifications buzzing whilst you are having a nap.
Jan89
Base Runner
@SunsetRunner you can
- disable notifications while at sleep via the app. (Sleep is recorded automatically)
- disable notifications altogether via long press of the left "button" on the charge
- Or just set your phone to do not disturb/silent or airplane mode. If notifications bug you on the charge I bet you don't want them to wake you when they appear on your phone
- leave your phone out of reach for the Bluetooth from your phone
- disable Bluetooth while taking a nap.
Hope that helps 😉
SunsetRunner
Not applicable
Yes, this! It would be ideal with a program for polyphasic sleep
KevWip
Recovery Runner
The other day I had a nap and I was surprised to see the Charge 3 identified it and add it to the app as "sleeping". So it would be pretty easy to add the "power nap" feature and ensure users don't slide into deep sleep.
lyssfitz
Recovery Runner
Would be even better if it could wake you before getting to a certain phase of sleep. Or for that matter even when in a longer sleep, if it could wake you when you're at a lighter sleep phase between a set time frame (I think there are some phone apps that do something like this but would be great with the fitbit and synced to your heart rate etc.)
