I have been having problems trying to get my fit bit versa to sync properly. It always takes more than one try to get the data to stay synced. Syncing the data to my account gets interrupted frequently and if the data for a certain day is not synced properly it seems to get lost forever. The normal troubleshooting steps do not keep the problem solved long-term and there needs to be a permanent fix to this bug.
Moderator Edition: Updated title for clarity
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
