It's quite possible to pair Apple AirPods to the Ionic and listen to tracks I've uploaded to the watch, but it's currently impossible to change the volume or pause and resume music using the onscreen controls.
Please fix this, if only because when I'm running I often want to adjust the music volume depending on environmental noise levels. As it is, the inability to adjust volume level is a potential hazard, both in terms of my hearing and for my safety while out running in built-up areas.
Also, if you press the music pause button on the Ionic, it's impossible to resume play again when listening on AirPods.
AirPods are currently the most popular 'truly wireless' earbuds on the market. I think this should be a priority update. Just my two cents.
Thanks
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
