Removing certain exercises from the fitbit auto recognition
If certain exercises aren't required on fitbit they should be easily removed from the exercises that are on the fitbit app. They should be able to be completely removed by the person using whichever fitbit they have if certain exercises aren't being used. Auto recognition should only pick up the exercises the person has chosen to use as well.
2 Comments
Status changed to: Needs More Info
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi @weatie. Thank you for sharing your Product Feedback with the Fitbit Community. We'd like to share with you that SmartTrack and Auto Detect (for certain Fitbit devices) have the option to disable automatic tracking for the exercise of your selection. For more information, check the following help articles:
On the other hand, if you're referring to something different, please reply with more detail or specifics on how this idea would work or what problem this is trying to solve. We look forward to your response.
weatie
Jogger
Hi,
What I would like is the exact exercises that you don't use i.e sport,
elliptical, etc specific exercises that you don't you that you can take off
and just keep the specific ones that you use regularly
Many thanks
Weatie
