Screen timeout on Fitbit Sense
I just started using my Sense today after 3 years with an Ionic so learning as I go but I cant find anyway to extend the screen time "on" seems to be set at about 5 seconds and I use to have my Ionic set to 20 seconds
Is it me or is this feature no longer an option
1 Comment
Status changed to: Existing Feature
YojanaFitbit
Moderator Alum
Moderator Alum
Hi @daro911, thank you for adding your suggestion. I'd like to let you know that you can find this option on your Fitbit Sense. You will see this option on: Settings > Display > Screen Time. You can choose from 8 to 60 seconds. If you have more questions visit: Adjust settings Fitbit Sense.
