add an option in settings to change between wearing the Fitbit on the outside or inside of the wrist and change things accordingly. The most important change being the quick view direction. I wear my charge HR on the inside of my wrist because it seems to get better HR readings and I find it more comfortable, but the quick view direction is reversed and i lose battery very fast from it turning on so often by accident. (I have turned off quick view as a result).
I know many people who wear their Fitbit on the inside of the wrist and I feel that this feature will be really helpful to those that do.
Moderator edit: Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
