Single unit that works as Dongle and charging cable
In today's days, where everything is compact and sleek (and competitors already used it), the charger cable should also support syncing the device at the same time (here: FitBit One).
Moderator Edit: Clarified subject and updated label
5 Comments
WUA
Base Runner
Would that effect the life of the battery to charge it everyday? Does the batery last longer when it is run out a little further for tose who sync more often?
Collin1000
Premium User
Veteran Runner
The fitbit Ultra was only one dongle - charger and sync. I have no idea why they moved to two dongles for the One.
My guess is because now with the Flex, Force, and One, being different sizes, they each needed different types of charging cables, so it was easier to make one dongle for everything for syncing, and then different chargers as needed. But still, I'd really like two see them go back to what they did with the Ultra when the charging base station was also the sync dongle.
jmcbeth
Jogger
This assumes that you will be using your computer, and more specifically the one that has Fitbit Connect installed on it, to charge your Fitbit.  You could just as easily charge it from a USB wall charger, your car, or a computer without Fitbit connect installed.
Status changed to: Reviewed By Moderator
AmritaFitbit
Premium User
Progression Runner
Thanks for your suggestion about making the dongle and charging cable one unit! We'll be sure to pass this feedback along to the team.
Status changed to: Not currently planned
LizzyFitbit
Premium User
Fitbit Moderator
Fitbit Moderator
Hi everyone, and thanks so much for sharing this suggestion about making a single unit that works as dongle and charging cable for Fitbit devices with us. While we don’t currently have plans to release this feature, we always appreciate the passion and creativity that comes out of this Community. Since we know this idea is important to many of you, we have left voting open to continue tracking interest and will post another update if anything changes. To learn more about how Fitbit decides which suggestions get developed, visit our FAQs.
We're always striving to enhance Fitbit products and services, and your input is a big part of that process. We truly thank you for taking the time to share your feedback with us.
