I work in a warehouse and use a step stool or step ladder constantly during my shift. I probably step up (normal stair height or greater) in excess of 2000 times in one shift (equal to probably close to 150-175 flights of stairs), however my fitbit registers 0.
Fitbit needs to be able to recognize any change in elevation (equal to a normal stair height) and save those to total the number in order to calculate the number of flights of stairs climbed. This type of climbing is no different than doing it on a flight of stairs, just that it's not doing it all at the same time. This would be similar to walking 10,000 steps, but doing them in place, and the fitbit saying you had 0 steps.
Moderator Edit: Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
